Extensions
Extension are programs integrated with HyperWorks to enhance or extend the user experience.
These programs are a collection of resources including, scripts, images, and dlls defined through a .config file. Extensions can be registered by script or through the program's extension manager. Extensions can span multiple profiles, displaying the appropriate controls as you switch between profiles.
Extension Manager
Extension manager allows you to register, view currently registered, and load/unload/remove extensions. The manager, located in the file pulldown, displays details about each registered extension including name, version, and descriptions.
Note: Extensions and the Extensions Manager support all HyperWorks clients.
