Run
From the Analyse ribbon > Analysis tool group > Run tool, click the arrow, , to launch the Generate and Run Seam
Solver tool, which runs the SEAM
code to analyze the model after it is generated. Select the necessary options
from the Seam Run dialog and click Run.
SEAM displays its progress, which may be closed after the run is completed.
- From the Analyse ribbon > Analysis tool group > Run tool, click the Contour Seam Results tool, , to define the contour.
- From the guidebar, , select inplane or bending, the type of contour to create (Energy), and frequency of interest.
Click Contour.
