When creating a model, you may have to modify or recreate the subsystem based on
different SEA creations, like Noise Control Treatments, connections, excitations,
leaks, and so on.
From the Edit tool group, use the Split or
Merge tools to modify subsystems, such as Boolean
operations. Figure 1.
Note: This is only supported for a Plate
subsystem.
