A merge can be based on a subsystem or line.
From the , click the Merge tool.
Select a subsystem to merge. The selected subsystem must have a node/point
connected on at least one edge.
![](../../../images/seam/sea_subsystems_edit_merge.png)
To merge lines/edges of a different subsystem, use the lines option under the
entity selector.
![](../../../images/seam/sea_subsystems_edit_merge_line.png)
Once your selections are complete, click Merge.
