Split Subsystems
From the Model toolbar > Edit tool group, click the Split tool.
Select a subsystem to split.
Figure 1. -
Pick Node 1 and Node 2.
Figure 2. - Click Split.
- Area, property, and material information is updated, but you must reapply Noise Control Treatment (NCT) details. This prevents errors when applying NCT multiple times.
The component is split based on the node selection.
Figure 3.
