Application Area 4: Parameter Identification
Optimization can also be used to determine the required values for spring and damping constants. The example below illustrates a common scenario.
A simple spring mass system is defined. A force of 1N acts on Body-1 and a force of 2N acts on Body-2.
![](../../../images/solvers/optimization_param_id1.png)
- Design Objective
- Compute k1 and k2 such that spring 1 deflects by 3mm and spring 2 deflects by 4mm when a static analysis is done.
- Design Variables
- The spring stiffnesses k1 and k2.
