AEROF
I/O Options and Subcase Information Entry Used to request aerodynamic loads on aerodynamic control points.
AEROF = option
Argument | Options | Description |
option | <ALL, NO, SID> Default = ALL |
- This command is supported only for Aeroelastic Static Analysis.
- The SET command references box identification numbers.
- Output is in the units of force or moment.
- Only aerodynamic forces on boxes specified on the SET command will be output.
- The output is printed in the .trim ASCII file.
