UNITS
I/O Options and Subcase Information Entry The UNITS command can be used in the I/O Options section to define a system of units for the model.
UNITS = system
Argument | Options | Description |
system | <SI,
CGS, MPA,
BG> No default |
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
- This UNITS Data Entry is the same as the DTI,UNITS entry.
