HEAT
I/O Options and Subcase Information Entry Used to output Joule loss density results in electrical analysis.
HEAT (format) = option
Definition
Argument Options Description
format <H3D, blank>
Default = blank
H3D
Results are output in Hyper3D format (.h3d file).
blank
Results are output in all active formats for which the result is available.
option <YES, ALL, NO, NONE, SID>
Default = ALL
YES, ALL, blank
The Joule loss density result is output for all the grids in the model.
NO, NONE
The Joule loss density result is not output.
SID
If a set ID is given, the Joule loss density result is output only for grids listed in that set.
  1. Joule loss density result is output by default in electrical analysis.
