THERMAL
I/O Options and Subcase Information Entry The THERMAL command can be used in the I/O Options or Subcase Information sections to request temperature output for all heat transfer analysis subcases or individual heat transfer analysis subcases, respectively.
THERMAL (sorting, format_list), THRESH=thresh, RTHRESH=rthresh, TOP=topn, RTOP=rtop)= option
Argument | Options | Description |
sorting | <SORT1, SORT2, blank> | Only applies to the PUNCH format (.pch format) for Transient Heat
Transfer Subcase. It will be ignored without warning, if used elsewhere.
format | <PUNCH, OP2, PLOT, H3D, blank> |
THRESH | <thresh> Real Default = blank |
Specifies an absolute threshold under which temperature results should not be output. 7 |
RTHRESH | <rthresh> 0.0 < Real < 1.0 Default = blank |
Specifies a relative threshold, as a fraction of the maximum temperature, under which results should not be output. For example, if T is the maximum temperature in the model, then temperature results below T*rthresh are excluded from the output. |
TOP | <topn> Integer > 0 Default = blank |
Only the top "topn" temperature values should be output. |
RTOP | <rtop> 0.0 < Real < 1.0 Default = blank |
Only the top fraction "rtop" of the total number of temperature values should be output. For example, if TTOT is the total number of temperature values in the model, then only the top TTOT*rtop values are output. |
option | <YES, ALL,
NO, NONE,
SID> Default = ALL |
- Thermal output is only available for the heat transfer analysis solution sequence.
- The PUNCH output produces TEMP Bulk Data Entries, and the SID on the entries will be the subcase number (=1 if no SUBCASES are specified).
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Temperature output via the THERMAL output request is available for both Linear Steady-State Heat Transfer and Linear Transient Heat Transfer Analyses
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
- format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
- The threshold options (THRESH, RTHRESH, TOP, and RTOP) are available for Thermal and Transient Thermal Analyses only. Transient Thermal Analysis is not supported in OP2 format. SORT1 option should be specified for PUNCH file output to be used in HFILE-based Nonlinear One Step Transient Thermal Stress Analysis (NL-OSTTS). For H3D, the filter is applied to each dimension of elements (shells, solids, beams, welds, etc.), while for OP2 and PUNCH, it is applied to each element type (quad4, tria3, quad8, etc.).
