OS-T: 1300 Direct Frequency Response Analysis of a Flat Plate
This tutorial demonstrates how to import an existing FE model, apply boundary conditions, and perform a finite element analysis on a flat plate.
Before you begin, copy the file(s) used in this tutorial to your working directory.
The flat plate is subjected to a frequency-varying unit load excitation using the direct method. Post-processing is done in HyperView and HyperGraph to visualize deformations, mode shape response, and frequency-phase output characteristics.
Launch HyperMesh and Set the OptiStruct User Profile
  1. Launch HyperMesh.
    The User Profile dialog opens.
  2. Select OptiStruct and click OK.
    This loads the user profile. It includes the appropriate template, macro menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for OptiStruct.
Import the Model
  1. Click File > Import > Solver Deck.
    An Import tab is added to your tab menu.
  2. For the File type, select OptiStruct.
  3. Select the Files icon files_panel.
    A Select OptiStruct file browser opens.
  4. Select the direct_response_flat_plate_input.fem file you saved to your working directory.
  5. Click Open.
  6. Click Import, then click Close to close the Import tab.
Set Up the Model
Apply Loads and Boundary Conditions
In the following steps, the model is constrained at one edge. A unit vertical load is applied acting upwards in the positive z-direction at a point on a free edge corner of the plate.
  1. Click the Model tab.
  2. In the Model Browser, right-click and select Create > Load Collector.
  3. For Name, enter spcs.
  4. Click Color and select a color from the color palette.
  5. Set the Card Image to None.
    A new load collector, spcs is created.
  6. In the Model Browser, right-click and select Create > Load Collector.
  7. For Name, enter unit-load.
  8. Click Color and select a different color from the color palette.
    A new load collector, unit-load is created.
Create Constraints
  1. In the Model Browser, expand Load Collector, right-click spcs > Make Current.
    rd2000_spc_load_collector
  2. Click the Display Numbers icon infoNumbers-24.
  3. Click nodes > displayed.
  4. Select on (green button).
    All of the node numbers on the flat plate should now be displayed.
  5. Click return to go back to the main menu.
  6. Click BCs > Create > Constraints to open the Constraints menu.
  7. Click the entity selection switch and select nodes from the pop-up menu.
  8. Click nodes and select nodes 5, 29, 30, 31 and 32 (Figure 2).
    os1100_pic1
    Figure 2. Nodes to Select for Applying Single Point Constraints
  9. Constrain dof1, dof2, dof3, dof4 and dof5 (you only need to uncheck dof6).
    • DOFs with a check will be constrained while DOFs without a check will be free.
    • DOFs 1, 2, and 3 are x, y, and z translation degrees of freedom.
    • DOFs 4, 5, and 6 are x, y, and z rotational degrees of freedom.
  10. Click create.
    The selected nodes will be free to rotate about the z-axis since dof6 was not checked.
  11. Click return to go back to the main menu.
Create a Unit Load at a Point on the Flat Plate
  1. In the Model Browser, right-click on the load collector unit-load and select Make Current.
  2. From the Analysis page, click load types.
  3. Select constraint = and select DAREA from the extended entity selection menu.
  4. Click return to exit the Load Types panel.
  5. Click BCs > Create > Constraints to open the Constraints menu.
  6. Select node number 19 on the plate by clicking on it (Figure 3).
    os1100_pic2
    Figure 3. Node Selected for Creating Unit Vertical Load
  7. Uncheck all the dof's except dof3 and click the = to the right of dof3 and enter a value of 20.
  8. Click load types= and verify that DAREA is selected from the extended entity selection menu.
  9. Click create, and then click return.
    The unit load is applied to the selected node.
Create a Frequency Range Table
  1. In the Model Browser, right-click and select Create > Curve.
    A new window opens.
  2. For Name, enter tabled1.
  3. In the table, enter x(1) = 0.0, y(1) = 1.0, x(2) = 1000.0, y(2) = 1.0.
  4. Close the Curve Editor window.
  5. From Curves, select tabled1.
  6. For Type, select TABLED1 from the drop-down menu.
    This provides a frequency range of 0.0 to 1000.0 with a constant 1.0 over this range.
Create a Frequency Dependent Dynamic Load
  1. In the Model Browser, right-click and select Create > Load Step Inputs.
  2. For Name, enter rload2.
  3. For Config type, select Dynamic Load – Frequency Dependent from the drop-down list.
  4. For Type, and select RLOAD2 from the drop-down list.
  5. For Excited, click Unspecified > Loadcol.
  6. In the Select Loadcol dialog, select unit-load from the list of load collectors and click OK to complete the selection.
  7. For TB, select the tabled1 curve.
    The type of excitation can be an applied load (force or moment), an enforced displacement, velocity or acceleration. The field Type in the RLOAD2 load step input defines the type of load. The type is set to applied load by default.
Create a Set of Frequencies
  1. In the Model Browser, right-click and select Create > Load Collector.
  2. For Name, enter freq1.
  3. Click Color and select a color from the color palette.
  4. For Card Image, select FREQi from the drop-down menu.
  5. Check the FREQ1 option and enter 1 in the NUMBER_OF_FREQ1 field.
  6. Update the following fields in the pop-out window.
    1. For F1, enter 20.0.
    2. For DF, enter 20.0.
    3. For NDF, enter 49.
  7. Click Close.
    This provides a set of frequencies beginning with 20.0, incremented by 20.0 and 49 frequencies increments.
Create a Load Step
  1. In the Model Browser, right-click and select Create > Load Step.
    A default load step template is now displayed in the Entity Editor below the Model Browser.
  2. For Name, enter subcase1.
  3. For Analysis type, select Freq.resp (direct) from the drop-down menu.
  4. For SPC, select Unspecified > Loadcol.
  5. From the Select Loadcol dialog, select SPCS.
  6. For DLOAD, select rload2 from the Select Load Step Inputs pop-out window.
  7. For FREQ, click Unspecified > Loadcol
  8. From the Select Loadcol dialog, select freq1.
    An OptiStruct subcase has been created which references the constraints in the load collector spc and the unit load in the load collector step input rload2 with a set of frequencies defined in load collector freq1
Create a Set of Nodes
  1. In the Model Browser, right-click and select Create > Set.
  2. For Name, enter SETA.
  3. For Card Image, select None.
  4. Leave the Set Type switch set to non-ordered type.
  5. For Entity IDs, select Nodes from the selection switch.
  6. Click Nodes and select nodes with IDs 15, 17 and 19.
  7. Click proceed.
Create a Set of Outputs and Mass Factors
  1. Click Setup > Create > Control Cards to open the Control Cards panel.
  2. Select GLOBAL_OUTPUT_REQUEST and check the box next to DISPLACEMENT.
  3. Under FORM(1), select PHASE from the pop-up menu.
  4. Under OPTION(1), select SID from the pop-up menu.
    A new field appears in yellow.
  5. Double-click the SID(1) box and select SETA.
    A value of 1 now appears below the SID field box. This sets the output for only the nodes in set 1.
    rd2000_displacement
    Figure 4.
  6. Click return to exit the GLOBAL_OUTPUT_REQUESTS menu.
  7. From the Control Cards panel, select FORMAT.
    A new window appears in the work area screen.
  8. Click number_of_formats = and input a value of 2.
  9. On the extended menu in the work area, click on the first FORMAT_V1 field box and select OPTI from the pop-up menu.
    Using OPTI generates OptiStruct ASCII result files like .disp, .strs, etc. as the output once the run is complete. These files are used during post-processing.
  10. Make sure the second field box is set to H3D.
  11. Click return to exit the Format menu and return to the Control Cards menu.
  12. Click next and select the PARAM subpanel.
  13. Scroll down the list using the arrow in the left corner and check the box next to COUPMASS.
    A new PARAM card appears in the work area screen.
  14. Click NO below COUPM_V1 and select YES from the pop-up menu selection.
    Selecting YES uses the coupled mass matrix approach for eigenvalue analysis.
  15. Scroll down the list using the arrow in the left corner and check the box next to G.
  16. Click below G_V1 and input a value of 0.06 into the field box.
    This value specifies a uniform structural damping coefficient and is obtained by multiplying the critical damping [] ratio by 2.0.
  17. Scroll down using the arrow in the left corner and check the box next to WTMASS.
  18. Click below WTM_V1 and input a value of 0.00259 into the field box.
    Three PARAM statements now appear in the pop-up menu on the work screen. This factor is used to input all mass entries in weight units. Using this PARAM multiplies all terms in the mass matrix by this factor.
    rd2000_param
    Figure 5.
  19. Click return to exit the PARAM menu.
  20. Select the OUTPUT subpanel.
  21. Verify that KEYWORD is set to HGFREQ.
    Using HGFREQ results in a frequency output presentation for HyperGraph.
  22. Click on the box beneath FREQ and select ALL from the pop-up selection to choose all outputs results for all frequencies.
  23. Leave number_of_outputs set equal to 1.
  24. Click return to exit OUTPUT.
  25. Click return to exit the Control Cards panel.
Submit the Job
  1. From the Analysis page, click the OptiStruct panel.
    OS_1000_13_17
    Figure 6. Accessing the OptiStruct Panel
  2. Click save as.
  3. In the Save As dialog, specify location to write the OptiStruct model file and enter flat_plate_direct_response for filename.
    For OptiStruct input decks, .fem is the recommended extension.
  4. Click Save.
    The input file field displays the filename and location specified in the Save As dialog.
  5. Set the export options toggle to all.
  6. Set the run options toggle to analysis.
  7. Set the memory options toggle to memory default.
  8. Click OptiStruct to launch the OptiStruct job.
If the job is successful, new results files should be in the directory where the flat_plate_direct_response.fem was written. The flat_plate_direct_response.out file is a good place to look for error messages that could help debug the input deck if any errors are present.
The default files written to the directory are:
flat_plate_direct_response.html
HTML report of the analysis, providing a summary of the problem formulation and the analysis results.
OptiStruct output file containing specific information on the file setup, the setup of your optimization problem, estimates for the amount of RAM and disk space required for the run, information for each of the optimization iterations, and compute time information. Review this file for warnings and errors.
flat_plate_direct_response.h3d
HyperView binary results file.
flat_plate_direct_response.res
HyperMesh binary results file.
flat_plate_direct_response.stat
Summary, providing CPU information for each step during analysis process.
View the Results
This step describes how to view displacement results (.mvw file) in HyperGraph and also explains the displacement output (.disp file) from this run.
The HyperView results (.h3d file) contains only the displacement results for the three nodes specified in the node set output.
  1. From the OptiStruct panel, click HyperView.
    HyperView is launched and the results are loaded. A message window appears to inform of the successful model and result files loading into HyperView.
  2. Click Close to close the message window, if one appears.
  3. In the HyperView window, click File > Open > Session.
    The Open Session File window is displayed.
  4. Select the directory where the job was run and select the file flat_plate_direct_response_freq.mvw.
  5. Click Open.
    A warning appears asking whether to discard the existing contents.
  6. Click Yes.
    Two graphs per page and a total of three pages are displayed. The graph title shows Subcase 1 Displacement of grid 15 on page 1.
    There are two sets of results on this page. The top graph shows Phase Angle verses Frequency (log). The bottom graph shows Magnitude versus Frequency (log) (see Figure 7) for Displacement of grid 15.
    rd2000_results
    Figure 7. Frequency Response of Node 15
  7. Click the Next Page icon pageNext-24.
    This displayed page 2, which shows Subcase 1 (subcase1) - Displacement of grid 17 (Figure 8).
    rd2000_results2
    Figure 8. Frequency Response of Node 17
  8. Select the Next Page icon pageNext-24 again to display page 3 containing Subcase 1 (subcase1) - Displacement of grid 19 (Figure 9).
    rd2000_results3
    Figure 9. Frequency Response of Node 19
    This concludes the HyperGraph results processing.
  9. Open the displacement file (.disp) using a text editor.
    The first field on the second line shows the iteration number, the second field shows the number of data points, and the third field shows the iteration frequency.
    Line 3, first field shows node number, then x, y, and z displacement magnitudes and x, y and z rotation magnitudes.
    Line 4, first field shows node number, then x, y, and z displacement phase angles and x, y and z rotation angles.
