Array Board Size Check
Check an item for the panel board size, whether or not the size is standard. Follow the instructions to set checking parameters.
- Option
- Consider Board Outline’s Line Width As Zero: If this item is selected, PollEx DFM ignores the width of board contour line’s width.
- Display All Results: Display all pass and fail results of the checked items.
- Board Size Comparing: In defining whether the result is a fail or pass, use
PollEx DFM to compare the size for one or two
sides of the PCB design.
- Size matching with X or Y will be passed: If the given size is matching with X or Y, it is passed.
- Size matching with X and Y will be passed: If the given two sizes are matching with X and Y, it is passed. If the given panel sizes are matching with Y and X, it is passed.
- Checking
- Item: Specify the item name.
- One Side, The Other Side: Set the standard size of the Array Board. If the Board size of PCB Design is matched with the given value or range, it is considered as a pass. To input the size, use the Floating Data Input dialog. Double-click the column and a window will be appear to setup the value and ranges.
- Fix_XY: Using this option, you can check the exact panel size for X and Y. X should be matching with value in One Side and Y should be matching with the value in The Other Side column.
- Condition: Check to enable the condition. When this option is checked, the checking criterion is only valid when a component is in a component group on the next column. If a component is not included in the component group, this checking criterion is skipped.
- Component Group: Define a component group. This is activated when the condition is checked.
