Overlay Plots
Compare two or more plots in the Results window. You can use the plot options while comparing to analyze the plot results.
Overlay feature is allowed to the following criteria:
  • Series files from the same or different job
  • Same extension files from the same or different job
  • Same result file from different jobs are allowed to overlay and compare the job results.
