rpti::item get
Queries the value of one property or role or attribute.
- Syntax
 rpti::item get
- Parameters
- -id
 - Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
- For
 - Value: A full list of standard property names see Supported
                                    property name above. Use
rpti::item getpropertykeylistfor list of dynamic properties.
- Returns
 - The value of the specified property/role/attribute or .tcl-error in case of error.
- Example
 rpti::item get -id $id -property parent usage: rpti::item get -id $id -role rolename usage: rpti::item get -id $id -attribute attributename
rpti::item getattribute
Get item attribute.
- Syntax
- Parameters
- -id
 - Value: Item ID.
- -name
 - Value: Attribute name.
rpti::item getinterface
Get Item Interface.
- Syntax
- Parameters
- -name
 - Value: Report session name.
rpti::item getpropertyid
Queries ID of property.
- Syntax
- Parameters
- -id
 - Value: Item ID.
- -key
 - Value: Property key.
Queries list of properties.
- Syntax
- Parameters
- -id
 - Value: Item ID.
- Returns
 - List of property keys for a particular item ID.
rpti::item getrole
Get item role.
- Syntax
 rpti::item getrole
- Parameters
- -id
- -name
 - Value: Role name.
- Returns
 - The role value.
rpti::item getroot
Queries the ID of the report root item.
- Syntax
 rpti::item getroot
- Parameters
- -id
 - Value: Item ID.
- Returns
 - The ID of the report root item.
rpti::item getselection
Queries current selected item.
- Syntax
- Returns
 - The selected item ID.
rpti::item getSlideLayouts
Queries Slide Layouts. Existing slides in a presentation is treated as slide layouts.
- Syntax
- Returns
 - The list of layout IDs.
rpti::item gettype
Queries the type of the item with the specified ID.
- Syntax
 rpti::item gettype
- Parameters
- -id
 - Value: Item ID.
- Returns
 - The type of the item.
rpti::item getypelist
Queries available types of items.
- Syntax
 rpti::item gettypelist
- Returns
 - A list of item types.
