rpti::item::property
Interact with items of type property.
- Supported Property Names
 -name -value -type(create only) -command -setcommand -validatecommand -visible -enabled
- Parameters
- -id
 - Value: Item ID. Not used.
rpti::item::property create
Creates an item of type "property".
- Syntax
- Parameters
- -id
 - Mandatory value: Parent item ID of type text,image,table,module etc, \paren
- -key
 - Mandatory value: Unique key/name for the property.
- -name
 - Value: "Display name of the property, if not specified key is used as display name".
- -type
 - (defaults to str): Type of property.
- For
 - Value: A full list of standard property names see Supported property name above.
- Returns
 - The ID of the item or .tcl-error in case an error occurred during creation.
- Example
 rpti::item::property create -id $parentid -key "MyKey" -name "My Property" -value "My Value" -type "str"
rpti::item::property delete
Deletes the item with the specified ID.
- Syntax
- Parameters
- -id
 - Mandatory value: Parent item ID of type text,image,table,module, and so on.
- -name
- Returns
 - 1 for OK, .tcl-error in case of error.
- Example
 rpti::item::property delete -id $id
rpti::item::property get
Queries the value of one property.
- Syntax
- Parameters
- -id
 - Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
- For
- Returns
 - The value of the specified property or .tcl-error in case of error.
- Example
 rpti::item::property get -id $id -property parent
rpti::item::property set
Sets name and value of specific property.
- Syntax
- Parameters
- -id
- For
- Returns
- Example
 rpti::item::property set -id $id -setcommand "::setCommand" -command "::cmdcallback"
