rpti::item has
Check if an item attribute, property or role exists.
rpti::item hasattribute
Check if an item attribute exists.
- Syntax
- Parameters
- -id
 - Value: Item ID.
- -name
 - Value: Attribute name.
- Returns
 - 1 if role exists, 0 if role does not exist.
rpti::item hasProperty
Check if the item has property with specified key.
- Syntax
- Parameters
- -id
 - Value: Item ID.
- -key
 - Value: Property key.
- Returns
 - 1 if valid, 0 if invalid.
rpti::item hasrole
Check if an item role exists.
- Syntax
 rpti::item hasrole
- Parameters
- -id
 - Value: Item ID.
- -name
 - Value: Role name.
- Returns
