rpti::item remove
Remove an item from parent.
- Syntax
 rpti::item remove
- Parameters
- -id
 - Value: Item ID. Item ID to remove.
- Returns
 - 1 if success, error message if failed.
rpti::item removerole
Remove item role if exists.
- Syntax
- Parameters
- -id
 - Value: Item ID.
- -name
 - Value: Role name
