rpti::item::table
Interact with items of type table.
- Supported Property Names
 - To set table properties, use the following:
rpti::item::table create
Creates an item of type "table".
- Syntax
- Parameters
- For
 - A full list of standard property names see Supported property name above.
- Returns
 - The ID of the item or .tcl-error in case an error occurred during creation.
- Example
 rpti::item::table create -name "My Table Item"
rpti::item::table delete
Deletes the item with the specified ID.
- Syntax
- Parameters
- -id
 - Value: Item ID. The item ID which is returned by the corresponding "create" API.
- Returns
 - 1 for OK, .tcl-error in case of error.
- Example
 rpti::item::table delete -id $id
rpti::item::table get
Queries the value of one property.
- Syntax
- Parameters
- -id
- For
 - Value: A full list of standard property names see Supported property name above.
- Returns
 - The value of the specified property or .tcl-error in case of error.
- Example
 rpti::item::table get -id $id -property parent
rpti::item::table getcell
Queries the value on a cell identified by row and column ID. Row and column IDs start with 0.
- Syntax
- Parameters
- -id
- -row
 - Mandatory value: Row ID. The ID of the row.
- -column
 - Mandatory value: Column ID. The ID of the column.
- -property
 - Mandatory value: 'value', 'href', 'color', 'textcolor', 'fontname', 'fontstyle', 'horizontal_alignment' and 'vertical_alignment'
- Returns
- Example
 ardi::item::text set -id $id -name "My Text Item" -value "Good monring, how are you today?"
rpti::item::table getheader
Queries the header text on a row or on a column. Row and column IDs start with 1. Specify either row or column ID to query the current value.
- Syntax
- Parameters
- -id
 - Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
- -row
 - Mandatory value: Row ID. The ID of the row you want to query the header text.
- -column
 - Mandatory value: Column ID. The ID of the column you want to query the header text.
- Returns
 - The header text, .tcl-error in case of error.
- Example
 rpti::item::table getheader -id $id -column 1
rpti::item::table getpropertyid
Queries ID of property.
- Syntax
- Parameters
- -id
- -key
 - Value: Property key.
rpti::item::table getpropertykeylist
Queries list of properties
- Syntax
- Parameters
- -id
- Returns
 - List of property keys for a particular item ID.
rpti::item::table set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
- Syntax
- Parameters
- -id
- For
- Returns
- Example
 rpti::item::table set -id $id -name "My Table Item" -value "Good monring, how are you today?"
rpti::item::table setcell
Sets the value on a cell identified by row and column ID. Row and column IDs start with 0.
- Syntax
- Parameters
- -id
- Returns
- Example
 rpti::item::table setcell -id $id -column 1 -value "My Header Text on column 1"
rpti::item::table setheader
Sets the header text on a row or on a column. Row and column IDs start with 0. Specify either row or column ID to set the header text to desired value.
- Syntax
- Parameters
- -id
- -row
 - Mandatory value: Row ID. The ID of the row you want to set a particular header text.
- -column
 - Mandatory value: Column ID. The ID of the column you want to set a particular header text.
- -value
 - Value: The text you want to set as header of the specified row or column ID.
- Returns
- Example
 rpti::item::table setheader -id $id -column 1 -value "My Header Text on column 1"
