rpti::item::module
Create or modify report modules.
rpti::item::module create
- Syntax
- Example
 rpti::item::module create -config "HwLoop"- Supported Property Names
 - To set loop results properties, use the following:
- name
 - Name
- Value
 - String
- hw_page Model
 - Model
- Value
 - Page 1/Window 2
 - Page window source
- comp_ids
 - Components
- Value
 - list of component ids
- group_ids
 - Sets
- Value
 - list of set ids
- add_displayed
 - Add displayed components
- lcase_options
 - Load Cases
- Value
 - Active, Last and Multiple
- lcase_datalist
 - Selected Load Cases
- Value
 - {simulationid subcasid}
 - {1 0}
- exclude_hide_etype
 - Entity Type
- Value
 - Sets and Components
 - Entity type for exclude and hide option
- mask_set_ids
 - Enity Selection (Set)
- Value
 - Set Ids
- mask_comp_ids
 - Enity Selection (Components)
- Value
 - Component Ids
- exclude_etype
 - Entity Type
- Value
- ignore_element_set_ids
 - Entity Selection(Set)
- Value
 - Set Ids
- ignore_component_ids
 - Entity Selection(Component)
- Value
 - Component Ids
- ignore_num_layers
 - Number of Layers
- Value
 - Integer
- loop_start
 - Start loop with
- Value
 - Component and loadcase
- add_complete_overview
 - Overview for each loadcase
- Value
 - 0 or 1
 - Enable overview for each loadcase
- exportopt
 - Export
- Value
 - All, Above, Below, EqualTo and Overview
- expcriteria
 - Export
- Value
 - real number
 - Export Criteria Value
- loop_over_hotspots
 - Loop Over Hotsport
- Value
 - 0 or 1
 - Enable loop over hot spots
- create_table.
 - Create results review table in the loop output. This is on by default.
- Value
 - 0 or 1.
 - Example
 ::ardi::item set -id $loopitemid -create_table 1
 - split_table
 - Auto Split Table
- Value
 - 0 or 1
- split_table_type
 - Split table by columns or rows
- Value
 - Columns or Rows
 - Auto split table by row or column
- split_rows
 - Maximum Rows
- Value
 - Integer
- split_cols
 - Maximum Columns
- Value
 - Integer
