Interact with items of type image.
                    - Supported Property Names
                    - To set image properties, use the following properties:
                                - label
                                - Caption and Location of caption.
                                            - Value
                                            - String, Below Image/ Above Image.
                                - hw_page
                                - Model location
                                            - Value
                                            - Page 1/Window 2
                                - hw_output
                                - Output Type
                                            - Value
                                            - PNG/JPEG/TIFF, for HyperMesh and other clients
                                            -  PNG/JPEG/TIFF/GIF/H3D, for HyperView and MediaView
                                                (in Document mode)
                                            - PNG/JPEG/TIFF/GIF/AVI/H3D, for HyperView and
                                                MediaView (in Presentation mode)
                                - crop
                                - Crop an image.
                                            - Value
                                            - 0 or 1.
                                - hw_best_view
                                - Best view.
                                            - Value
                                            - 0 or 1.
                                            - Enable or disable Best View
                                - hw_view_modes
                                - View mode.
                                            - Value
                                            - Isometric View, XY Top View, XY Bottom View, ZX
                                                Right View, XZ Left View, ZY Front View and YZ Rear
                                                View
Note: Applied only for HM/MV
                                            - HV view modes- Global View, Global Components,Global
                                                Regions, Global Spheres, Selection Transparency,
                                                Selection Isolate, Local Entity Zoom, Local
                                                Transparency, Local Contour, Isometric View, XY Top
                                                View, XY Bottom View, ZX Right View, XZ Left View,
                                                ZY Front View and YZ Rear View.
                                - hv_enable_note
                                - Create Note.
                                            - Value
                                            - 0 or 1.
                                - hv_note_on
                                - Note Location.
                                            - Value
                                            - Maximum of Contour, Minimum of Contour and Hotspots
                                                of Contour.
                                - hv_find_hotspots_at
                                - Find Hotspots.
                                            - Value
                                            - Above Threshold and Below Threshold.
                                - hv_hotspot_threshold
                                - Threshold
                                            - Value
                                            - Number
                                - hv_hotspot_distance
                                - Zone Distance
                                            - Value
                                            - Number
                                - hv_number_of_hotspots
                                - Maximum Hotspots
                                            - Value
                                            - Number
                                - hv_note_text
                                - Note Text
                                            - Value
                                            - String
                                            - Example
                                            - Value: { format %0.3f {entity.contour_max}}
                                - hv_note_bg_color
                                - Fill Color
                                            - Value
                                            - rgbcolor
                                            - Example
                                            - "200 100 100"
                                - hv_note_fill_color_mode
                                - Fill Color Mode
                                            - Value
                                            - User, Component and Contour.
                                - hv_note_text_color
                                - Text Color
                                            - Value
                                            - rgbcolor
                                - hv_note_text_color_mode
                                - Text Color Mode
                                            - Value
                                            - User, Maintain Contrast, Component and Contour.
                                - hv_note_align_text
                                - Align Text
                                            - Value
                                            - Left, Center and Right.
                                - hv_note_border_thickness
                                - Border thickness
                                            - Value
                                            - Number (0-4)
                                - hv_note_border_color
                                - Border Color
                                            - Value
                                            - rgbcolor
                                - hv_note_border_color_mode
                                - Border Color Mode
                                            - Value
                                - Border Color Mode
                                            - Value
                                - hv_note_font_family
                                - Font Family
                                            - Value
                                            - String
                                - hv_note_font_style
                                - Font Style
                                            - Value
                                            - Regular, Italic, Bold and Bold Italic
                                - hv_note_font_size
                                - Font Size
                                            - Value
                                            - Number
                                - hv_note_transparent
                                - Enable Transparency
                                            - Value
                                            - 0 or 1
                                - hv_note_shape
                                - Note Shape
                                            - Value
                                            - Rectangle, Circle and Ellipse.
                                - hv_note_position_to_attachment
                                - Note Position To Attachment
                                - hv_note_auto_hide
                                - AutoHide
                                            - Value
                                            - 0 or 1
                                - hv_note_screen_anchor
                                - ScreenAnchor
                                            - Value
                                            - 0 or 1
                                - hv_hide_local_system
                                - Hide Local System
                                            - Value
                                            - 0 or 1
                                - hv_hide_modelinfo_note
                                - Hide Model Info Note
                                            - Value
                                            - 0 or 1
                                - hv_auto_fit
                                - AutoFit
                                            - Value
                                            - 0 or 1
                                - hv_legend_file
                                - Legend file
                                            - Value
                                            - Valid legend file name with full path
                                - hv_update_legend
                                - Set Dynamic Legend
                                            - Value
                                            - 0 or 1
                                - hv_capture_option
                                - Capture option.
                                            - Value
                                            - Legend and Graphics Area, Graphics Area and Legend
                                                only.
                    - Example
                    ::rpti::item set -id $imageobid -label "My Image" -position "Above
                            Image"
                    ::rpti::item GetPropertykeylist
         rpti::item::image create
            Creates an item of type "image".
                    - Syntax
                    - Parameters
                                - For
                                - Value: A full list of standard property names see Supported
                                    property name above.
                    - Returns
                    - The ID of the item or .tcl-error in case an
                        error occurred during creation.
                    - Example
                    rpti::item::image create -name "My Image Item"
        rpti::item::image delete
            Deletes the item with the specified ID.
                    - Syntax
                    - Parameters
                                - -id
                                - Mandatory value: Item ID. The item ID which is returned by the
                                    corresponding "create" API.
                    - Returns
                    - 1 for OK, .tcl-error in case of error.
                    - Example
                    rpti::item::image delete -id $id
        rpti::item::image get
            Queries the value of one property.
                    - Syntax
                    - Parameters
                                - -id
                                - For
                    - Returns
                    - The value of the specified property or .tcl-error in case of error.
                    - Example
                    rpti::item::image get -id $id -property parent
        rpti::item::image getpropertyid
            Queries ID of property.
                    - Syntax
                    - Parameters
                                - -id
                                - Value: Item ID.
                                - -key
                                - Value: Property key.
        rpti::item::image getpropertykeylist
            Queries list of properties.
                    - Syntax
                    - Parameters
                                - -id
                                - Value: Item ID. The item ID which is returned by the
                    - Returns
                    - List of property keys for a particular item ID.
        rpti::item::image set
            Sets one or multiple parameters to specified values. The type of the item is assigned
                upon creation and cannot be changed after.
                    - Syntax
                    - Parameters
                                - -id
                                - For
                    - Returns
                    - Example
                    rpti::item::image set -id $id -name "My Image Item" -value "Good
                            monring, how are you today?"
