Rattle Evaluation
The rattle evaluation is based on the assessment of relative displacement between two parts along the defined E-Line. The relative displacement is compared to the Gap and Tolerance values defined during the pre-processing workflow.
- Relative displacement magnitude and in local Z-direction.
- Dynamic Tolerance is defined as:
Gap [mm] - Tolerance [mm] - Relative Dsiplacement in Z
In addition, SnRD proposes an unit-less Contact Rattle Index (CRI) coupled to the material pair along the rattle E-Line. Named as Contact Type, this criterion is based on material stiffness values.
Contact Types
- Soft: materials such as foam, leather and rubber- default Youngs(E) Modulus < 500 MPa
- Medium: soft plastics material- 501 MPa < E-modulus < 10000 MPa
- Hard: hard plastics, metals, glass materials- E-modulus > 10000 MPa
Issue and risk areas are easily identified, guiding the analyst for deeper investigation of root cause and problem solving.
