Collectors Menu
Aerospace offers the following functions in the Collectors menu:
        | Assemblies | Create and modify assemblies, which are collections of component and multibody collectors or other assemblies. |
| Components | Create and update components. |
| Load Collectors | Load collectors contain the loads applied to entities, such as pressures, fluxes or forces. |
| Vector Collectors | Vector collectors contain vectors which can then be used to define loads or transformations. |
| System Collectors | System collectors contain coordinate systems, which can then be applied to different components of a model. |
| Beam Section Collectors | BeamSection Collectors contain beam section data. |
| Multibodies | Multibodies are jointed bodies made up of multiple parts and are often used to simulate crash test dummies and similar objects during crash analysis. |
| Organize | Reorganize your database by copying or moving data (entities) among collectors or includes. |
| Rename | Change the name of a specific collector or to rename types of collectors to their respective ID with an optional prefix. |
| Renumber | Renumber entities. |
| Reorder | Change the order of named entities in database. |
| Color | Change the color attributes of a collector |
