Properties Menu
The following functions are offered in the Properties menu:
        - HyperBeam
- Create beam cross-section entities that you can use to simplify complex portions of your model into simple bar elements.
- HyperLaminate
- Create, review and edit collectors and card images or dictionaries.
- Laminates
- Laminates are collections of Plies (or in some cases other laminates) that are considered to be fastened together into a single structure for purposes of simulation.
- Organize
- Reorganize your database by copying or moving data (entities) among collectors or includes.
- Plies
- Ply entities are used to represent layers in a laminated composite material, such as carbon fiber or fiberglass composites.
- Properties
- Create property collectors, which can be used to assign physical properties to entities.
- Renumber
- Renumber entities.
