Show, Hide, and Isolate Using the Mask Browser
Tip: To determine whether the masking operations for morph entities apply to
                all/displayed elements, right-click in the browser and select Morph
                    operates on all elements / Morph operates on displayed
                    elements.
         to show the relevant entities for the current row
                        and sub-folders. For example, the Show icon at the Geometry folder unmasks
                        all points, lines, surfaces and solids within any displayed
                        components.
                        components. to hide the relevant entities for the current row
                        and sub-folders. For example, the Hide icon at the 1D folder masks all rod,
                        bar2, bar3, weld, joint and plot elements within any displayed
                        components.
                        components. to perform a Hide on the top level folder and then
                        a Show on the current row and sub-folders.
