Adding an Assembly with a New Data File Which References an Existing Definition File
Note: An assembly cannot be added to a system or inline analysis.
From the Add System/Assembly dialog, activate the
Assembly radio button and click
Next.
The Add Assembly dialog is displayed.
- Activate the New data file radio button and click Next.
- Activate the Existing definition file radio button and click Next.
- Optional: To change the parent entity in which the new assembly will be stored, double-click the Parent collector and select an assembly or analysis from the Model Tree.
- Click the file browser icon under New Data File.
- Select a path and file name and click Save.
- Click the file browser icon under Existing Definition File.
Browse and select the definition file
to
use then click Open.
The definition name and type referenced by the data file will automatically be displayed in their respective fields.
- Specify a variable name for the assembly.
- Specify a label for the assembly.
Click OK to close the window or
Apply to continue creating entities.
The assembly is added to the model.
