Edit a System
Clicking on the System in the Project Browser opens a panel, where you can make edits to the selections.
In addition to converting compliant joints, MotionView can turn other entities on or off in a system according to predefined system settings. For example, MotionView can turn off specific entities such as springs or stabilizer bars when the system is made non-compliant.
- The Compliant option is applied to all subsystems beneath the current system.
 - The Compliant option can be overridden for individual joints in the Joints panel.
 - Not all joints can be compliant. The rules for converting joints from compliant to non-compliant are built into each model using the MDL language.
 - See *Option() in the MDL Language Reference for more information on creating options.
