Adding an Assembly with a New Data File and a New Definition File
Note: An assembly cannot be added to a system or inline analysis.
From the Add System/Assembly dialog, activate the
Assembly radio button and click
Next.
The Add Assembly dialog is displayed.
- Activate the New data file radio button and click Next.
- Activate the New definition file radio button and click Next.
- Optional: To change the parent entity in which the new assembly will be stored, double-click the Parent collector and select an assembly or analysis from the Model Tree.
- Click the file browser icon under New Data File.
- Select a path and file name and click Save.
- Click the file browser icon under Existing Definition File.
- Assign a defenition name to the defenition file or accept the default name.
- Assign a type for the definition file if necessary.
- Specify a variable name for the assembly.
- Specify a label for the assembly.
Click OK to close the window or
Apply to continue creating entities.
The assembly is added to the model.
