Add an Assembly Using an Existing File
Note: An assembly cannot be added to a system or inline analysis.
                From the Add System/Assembly dialog, activate the
                        Assembly radio button and click
                        Next.
                The Add Assembly dialog is displayed.
 - Activate the Existing data file radio button and click Next.
 - Optional: To change the parent entity in which the new assembly will be stored, double-click the Parent collector and select a assembly or analysis from the Model Tree.
                Click the file browser icon under Existing Data File.
                The Select Data File dialog is displayed.
                Browse and select the data file to use and click
                    Open.
                The definition file, name, and type referenced by the data file will automatically be displayed in their respective fields.
 - Specify a variable name for the assembly.
 - Specify a label for the assembly.
                Click OK to close the window or
                        Apply to continue creating entities.
                The assembly is added to the model.
