I/O Options Defaults Summary
Output Format Controls
Card | When card is not present | When card is present, but no argument is given |
OUTPUT | No effect | No effect |
Note: The OptiStruct Configuration File
may be used to change the default settings.
Run Controls
CHECK | No effect | Active (has no arguments) |
CMSMETH | No effect | No effect |
RESTART | No effect | <prefix of filename>.sh |
SYSSETTING | No effect | No effect |
@ HyperForm | No effect | Active (has no arguments) |
File Names, Headers, and Locations
Analysis Output
ACCELERATION | NONE | ALL |
AUTOSPC | NO | YES |
CFAILURE | NONE | ALL/YES |
CONTF | NONE | ALL |
CSTRAIN | NONE | ALL |
CSTRESS | NONE | ALL |
DAMAGE | NONE | ALL |
DISPLACEMENT | ALL 2 | ALL |
EDE | NONE | ALL |
EKE | NONE | ALL |
ELFORCE | See FORCE | |
ELSTRESS | See STRESS | |
ENDLOAD | NONE | ALL |
ERP | NONE | ALL |
ESE | NONE | ALL |
FLUX | NONE | ALL |
FORCE | NONE | ALL |
GPFORCE | NONE | ALL |
GPKE | NONE | ALL |
GPSTRESS | NONE | ALL |
GSTRESS | See GPSTRESS | |
LIFE | NONE | ALL |
MBFORCE | no effect | ALL |
MECHCHECK | no effect | N/A |
MODALDE | NONE | ALL |
MODALKE | NONE | ALL |
MODALSE | NONE | ALL |
MPCFORCE | NONE | ALL |
NLLOAD | NONE | ALL |
OLOAD | NONE | ALL |
PFGRID | NONE | error |
PFMODE | NONE | error |
PFPANEL | NONE | error |
PFPATH | NONE | error |
POWERFLOW | NONE | ALL |
PRESSURE | ALL † | ALL |
PRETBOLT | NO | YES |
REQUEST | NONE | Error (has no arguments) |
SACCELERATION | NONE | ALL |
SDISPLACEMENT | NONE | ALL |
SINTENS | NONE | ALL |
SPCFORCE | NONE | ALL |
SPL | NONE | ALL |
STRESS | ALL 1 | ALL |
SVELOCITY | NONE | ALL |
TCURVE | N/A | Blank |
THERMAL | NONE | ALL |
THIN | NONE | ALL |
UNITS | NONE | Error (has no arguments) |
XTITLE | N/A | Blank |
XYPEAK | NONE | Error |
XYPLOT | NONE | Error |
XYPUNCH | NONE | Error |
YTITLE | N/A | Blank |
Optimization Output
Other Output Controllers
DMIGNAME | AX | AX |
ECHO | No effect | Active |
ECHOON | No effect | Active (has no arguments) |
ECHOOFF | No effect | Active (has no arguments) |
MODEL | ALL | ALL |
MSGLMT | No effect | Error |
OFREQUENCY | ALL | ALL |
OMODES | ALL | ALL |
OTIME | ALL | ALL |
SCREEN | NONE | OUT |
TTERM | NONE | REAL |
Random Response
RCROSS | None | Error |
Optimization
DGLOBAL | None | Error |
FE Analysis
Miscellaneous
DEBUG | For HW support use only | For HW support use only |
