THIN
I/O Options and Subcase Information Entry The THIN command can be used in the I/O Options or Subcase Information sections to request thinning and thickness output for all geometric nonlinear analysis subcases or individual geometric nonlinear analysis subcases, respectively.
THIN (format, type) = option
| Argument | Options | Description |
| format | <H3D, blank> |
| type | <ALL, THIN, THICK> |
| option | <YES, ALL, NO,
NONE, SID,
PSID> Default = ALL |
- THIN is only applicable for geometric nonlinear analysis subcases which are defined by an ANALYSIS = NLGEOM subcase entry.
- Only formats that have been activated by an OUTPUT statement are valid for use on this card.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
