/GRSPRI/GENE
Block Format Keyword Generate a group of spring elements by listing the first and last element IDs in the range.
For each list, enter first node and last node (any number of lists may be input, up to 5 per Line). All nodes between first_ID and last_ID are selected.
| /GRSPRI/GENE/grspri_ID/unit_ID | |||||||||
| grspri_title | |||||||||
| first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
Definition
| grspri_ID | Spring group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grspri_title | Spring group
| first_ID1, last_ID1,...first_IDn, last_IDn | List of first and last
spring identifiers (Integer) |
