/GRSPRI
Block Format Keyword Describes the spring groups.
Input Type Keywords: Spring Group
Keyword
Input Type
/GRSPRI/GEN_INCR
Generate list by increment
/GRSPRI/GENE
List of spring with generation
/GRSPRI/GRSPRI
Spring groups
/GRSPRI/MAT
Material
/GRSPRI/PROP
Property
/GRSPRI/SPRI
Spring numbers
  1. A spring group is a set of springs (only). It can be defined by a list of:
    • spring ID
    • subsets or parts (all springs belonging to the listed subsets/parts are included)
    • entering a first and last spring ID range which defines the group
    • submodels (all springs defined in the listed submodels are included)
    • property sets or materials (all springs having those Property Type's/MID's are included)
    • spring groups
    • a box (all springs within a defined box are included)
