/LINE/SEG
Block Format Keyword Definition of the line segments.
/LINE/SEG/line_ID/unit_ID
line_title
seg_ID1 node_ID1 node_ID2
seg_ID2 node_ID1 node_ID2
etc etc etc
seg_IDn node_ID1 node_ID2
Definition
line_ID Line group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
line_title Line group title
seg_ID1, seg_ID2, seg_IDn, List of segment identifiers (optional)
(Integer)
node_ID1 Node identifier 1 for segment
(Integer)
node_ID2 Node identifier 2 for segment
(Integer)
  1. Lines are used to define interfaces in 2D analysis and interface TYPE8, TYPE11 and TYPE20 in 3D analysis.
  2. All nodes must belong to a shell, brick, triangular shell, truss, or beam element.
