/MAT/LAW6 (HYDRO or HYD_VISC)
Block Format Keyword Describes a fluid material. Pressure is computed using Equation of State provided by definition of /EOS option.
/MAT/LAW6/mat_ID/unit_ID or /MAT/HYDRO/mat_ID/unit_ID or /MAT/HYD_VISC/mat_ID/unit_ID
mat_title
ρi ρ0
ν Pmin
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρi Initial density.
(Real)
[kgm3]
ρ0 Reference density used in E.O.S (equation of state).
Default = ρ0=ρi (Real)
[kgm3]
ν Kinematic viscosity.
(Real)
[m2s]
Pmin Pressure cut-off.
Default = -1.0 x 1020 (Real)
[Pa]
Example (Air)
  1. Sij=2ρνeqe˙ij
    Where,
    νeq=ν
    No turbulence
    Sij
    Deviatoric stress tensor
    e˙ij
    Deviatoric strain tensor
  2. Equation of state for hydrodynamic pressure has to be prescribed via the /EOS card.
  3. In case of a linear material with a volumetric dilatation:
    C1=E3(12ν) and C4=ανC1ρCνT
    C4=C5=γ1 and C0=C2=C3=0
    then:(1)
    p=C1μ+(C4+C5μ)E=C1μ+C4(1+μ)E=C1μ+C4(1+μ)ρ0e=C1μ+C4(1+μ)ρ0CνT
    (2)
    p=C1μ+C4ρCνT=C1μ+ανT
    If p=cst=0 , then C1μ+ανT=0 l=; so μ=ανTC1
    Where,
    μ
    Dilatation coefficient
    μ<0
    Dilatation
    In this case the parameters C2 and C3 will not be taken into account.
  4. All thermal data ( ρ0Cp,T0,A,andB ) can be defined with keyword /HEAT/MAT.
  5. If using LAW6 coupled with LAW37 for liquid phase (without gas phase), the compatibility of the liquid EOS is:
    • ΔP1=C1μ for /MAT/LAW37 (BIPHAS)
    • p=C0+C1μ+C2μ2+C3μ3+(C4+C5μ)E for LAW6 via a polynomial EOS defined as in the Example above.
    with C0=C2=C3=C4=C5=E=0 MathType@MTEF@5@5@+=feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbWaaSbaaSqaaiaaicdaaeqaaOGaeyypa0Jaam4qamaaBaaaleaacaaIYaaabeaakiabg2da9iaadoeadaWgaaWcbaGaaG4maaqabaGccqGH9aqpcaWGdbWaaSbaaSqaaiaaisdaaeqaaOGaeyypa0Jaam4qamaaBaaaleaacaaI1aaabeaakiabg2da9iaadweacqGH9aqpcaaIWaaaaa@46A9@
    then, p=C1μ
  6. If using LAW6 coupled with LAW37 for gas phase (without liquid phase), the compatibility of the gas EOS is:
    • PVγ=const. for LAW37
    • p=(γ1)(μ+1)E for LAW6, via the /EOS/IDEAL-GAS equation of state.
    Where, E MathType@MTEF@5@5@+=feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGfbaaaa@3832@ is the energy per unit volume.
