/SKEW/FIX
Block Format Keyword Describes the fixed skew frames.
/SKEW/FIX/skew_ID/unit_ID
skew_title
Ox Oy Oz
X1 Y1 Z1
X2 Y2 Z2
Definition
skew_ID Skew identifier
This ID must be different from all frame (/FRAME/FIX) identifiers
(Integer, maximum 10 digits)
unit_ID Unit Identifier
skew_title Skew title
Ox X coordinate of skew origin O'
(Real)
[ m ]
Oy Y coordinate of skew origin O'
(Real)
[ m ]
Oz Z coordinate of skew origin O'
(Real)
[ m ]
X1 X component of skew Y ' axis
(Real)
Y1 Y component of skew Y ' axis
(Real)
Z1 Z component of skew Y ' axis
(Real)
X2 X component of skew Z ' axis
(Real)
Y2 Y component of skew Z ' axis
(Real)
Z2 Z component of skew Z ' axis
(Real)
  1. For fixed skews, the skew system is fixed and is defined by Y ' and Z ' . Vectors of arbitrary length may be given.
  2. For a fixed skew, inputs are Y ' axis and Z ' axis, but X ′ axis is computed as: (1)
    X ′ = Y ' Λ Z '
    Y ' is recomputed as: (2)
    Y ″ = Z ′ Λ X ′
  3. The new fixed skew is defined by X ′ , Y ″ and Z ' .
  4. The skew origin O' is useful when defining some condition with respect to the skew in cylindrical coordinate system.
    fixed_skew_frame
