Step 2: Creation of the force computation and export of the harmonics
Introduction
CAUTION:
The mechanical analysis context of Flux will no longer be available in the near future; all the features of this context are fully available in the Data import/export context. The mechanical analysis context remains available in advanced mode.
This section explains how to create a Computation of surface magnetic forces on rotating machine imported mesh.
It is available through the menu Force computation > New or through the icon
The steps to create the force computation are described below. Images of the creation box are also available.
Step Action
1 Choose the name of the force computation (+comment)
2 Choose the method Computation of surface magnetic forces on rotating machine imported mesh
3 Choose the support created beforehand
4 Define the computation radius in airgap on ¼ distance of the airgap thickness, stator/rotor side, according to where the imported support is (see Computation radius in airgap and slots opening angle)
5 Choose the slots opening angle (See Computation radius in airgap and slots opening angle )
6
Choose the interval of computation according to the choice of applying or not a temporal duplication in the field Data to be computed (see Spatial and temporal definition).
Reminders :
  • The initial step and the final step are repeated
  • Do not take the first step of the scenario of the solving process as the first step of computation
7
Choose the data to be computed. You must choose :
  • Application or not of a temporal duplication (choice connected to the step 6)
  • The choice to calculate :
    • Only the forces
    • Or the forces with their harmonics
It is strongly recommended to calculate both forces and harmonics, as the calculation of the harmonics is rapid and necessary to export it
8
Verify if the time interval is in good correlation with :
  • The real mechanical frequency
  • The computed mechanical frequency (based on the computed interval)
  • The number of duplications
(see Spatial and temporal definitionSpatial and temporal definition )
9 Validate by OK
10
Re-open the computation box and verify :
11 Visualize the arrows of the forces or of the harmonics (see Postprocessing with forces arrows )
Step 1 to 9 :
Step 10 to 12 :
