Projection quality rate
Projection quality rate : interest
CAUTION:
The mechanical analysis context of Flux will no longer be available in the near future; all the features of this context are fully available in the Data import/export context. The mechanical analysis context remains available in advanced mode.
The forces projection quality factor will help to verify the good progress of forces computation and projection on the mechanical mesh.
Projection quality rate : Influence of application
According to the application dimension (2D, Skew, 3D), the projection and control methods are different.
The forces projection quality factor values (radial and tangent) could vary depending on the concerned applications.
Projection quality rate : In practice
The projection quality is not an absolute reference but a guide number to avoid aberrant results.
In practice, we will not try to reach an exact 100% quality.
It should be noted that the projection quality control method is more adapted to radial forces. So we will verify as a priority the projection quality of those components. The projection quality for tangent forces is given for information purposes only.
For example, we can consider that the radial projection quality is generally higher than 90%, whereas the tangent projection quality can be easily deteriorated to reach sometimes values around 50% for Skew applications especially.
