::GetValidLocationToAddItem
From the current selected item(s) in the browser, this command will return the deepest valid (full variable name) container (Assembly/System/Analysis/Template, etc.) for adding an instance of the specified registered entity type.
::model::GetValidLocationToAddItem argRegType
MotionView Tcl
- argRegType
 - We need to send registered entity type (Point,Body,Vector,….) that we are getting the valid location to add to as an argument.
set varParentOfSystem [::model::GetValidLocationToAddItem Point]
 if { [::model::IsValidVarname $varParentOfSystem] } {
          ::model::GetHandleFromFullVarname sh varParentOfSystem
          set new_varname "p_test"
          sh InterpretEntity ph Point $new_varname "\"Point 1\""
          ph InterpretSet SetPoint p_0 10 20 30
          ::model::EvaluateModel
          ph ReleaseHandle
         sh ReleaseHandle
# After this, a point gets created in the deepest container for all of the selected entities in the model browser
Returns the full varname of a container if successful.
