::mdlTempCollector
This command will be used to create a collector widget used to resolve a reference, but this widget will not be attached to any entity data members. Instead, it will set and retrieve the reference value from a Tcl variable. Like the mdlCollector widget, this widget will let the user pick an entity of the allowed type either graphically or from a tree.
::model::mdlTempCollector frmPath variable text pickType
MotionView Tcl
- frmPath
 - The frame on which the mdlTempCollector widget will be created is passed as an argument.
 - variable
 - We need to pass the name of the variable. The variable will hold the varname of the entity to which the collector is resolved.
 - text
 - This argument contains the name that is to be displayed in the mdlTempCollector widget.
 - pickType
 - The entity type that is allowed to be selected by the user to resolve this reference.
set selected_point ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set point_col [::model::mdlTempCollector $colFrm.ptcol ::selected_point "Point" "Point" ]
pack $point_col
On successful execution of the command, it will create a mdlTempCollector widget.
