::mdlNonLinear
This command will be used to create an mdlNonlinear widget, this widget contains a combobox and it allows the user to specify a curve, spline3D, value or expression properties based on the combobox selection.
::model::mdlNonLinear path entityHandle type eb
MotionView Tcl
- path
 - The frame on which the mdlNonLinear widget will be created is passed as an argument.
 - entityHandle
 - We need to pass the handle of the entity which contains the nonlinear data member.
 - dm
 - We need to pass the name of the data member that will be used by the mdlNonLinear widget.
 - eb
 - We need to pass a variable that holds the path of the edit bar address (Expression builder) to this argument. If the variable does not hold a path, the ::model::mdl3StateEntry widgets used within the mdlNonLinear widget would not be linked to the edit bar. That is, the user cannot use the edit bar to modify the value for the ::model::mdl3StateEntry.
set eb_frame ""
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity bshandle Bush bsh_0 "\"Bush0\"" "" "" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set xTypeList {}
set bsh_cb [::model::mdlNonLinear $colFrm.cb bshandle "ktx" ::eb_frame]
pack $bsh_cb
client ReleaseHandle
mod ReleaseHandle
bshandle ReleaseHandle
On successful execution of the command, it will create the mdlNonLinear widget.
