::mdlComboBox
This command creates an mdlComboBox widget that is tied to a list variable.
::model::mdlComboBox path entityHandle data args
MotionView Tcl GUI
- path
 - The full path to the newly created widget.
 - entityHandle
 - A handle pointing to the entity.
 - data
 - A list of strings containing the entry values and entry labels for the entries in the ComboBox drop down. For example: {"Value 1" "Value 2" "Value 3"}.
 - args
 - A list of '-' separated flags to configure the ComboBox widget's behavior.
::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity entCrv Curve crv_0 "\"Curve 0\""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set data { "2D Cartesian" "2D Parametric" "3D Cartesian" "3D Parametric"}
set cb [::model::mdlComboBox .dlg.frm.cb entCrv $data -label "Curve type:" ]
grid $cb -row 0 -column 0
entCrv ReleaseHandleErrors
Returns the path to a mdlComboBox widget if successful, otherwise an error code.
