::mdlForm
This command will be used to create a form widget and this will be attached to the form entity passed as an argument. This mdlForm widget is a “table”-like widget with its contents completely defined by the form entity defined in the MDL.
::model::mdlForm frmPath entityHandle
MotionView Tcl
- frmPath
 - The frame on which the mdlForm widget will be created is passed as an argument.
 - entityHandle
 - We need to pass the handle of the form entity for which we need to display the form widget.
# the gravity form is defined in the sys_misc system (defined in the standard include file)
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
::model::GetHandleFromFullVarname  frmhandle MODEL.sys_misc.frm_gravity
set bsh_cb [::model::mdlForm $colFrm.cb frmhandle]
pack $bsh_cb
frmhandle ReleaseHandle
On successful execution of the command it will create the mdlForm widget.
