::mdlMatrix
This command will be used to create an mdlMatrix widget. It contains a matrix of entry widgets based on the row and column numbers specified. If the number of rows and/or number of columns are not specified, the dimensions of the matrix will not be set.
::model::mdlMatrix path entityHandle dm -rows # -columns #
MotionView Tcl
- frmpath
 - The frame on which the mdlMatrix widget will be created is passed as an argument.
 - entityHandle
 - We need to pass the handle of the entity which contains the numeric vector data member.
 - dm
 - We need to pass the name of the data member that will be used by the mdlMatrix widget.
 - -rows #
 - We need to pass the number of rows to be used by the mdlMatrix widget. If this is not specified, 1 row is assumed.
 - -columns #
 - We need to pass the number of columns to be used by the mdlMatrix widget. If this is not specified, 1 column is assumed.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity fldhandle Field fld_0 "\"Field0\"" "" "" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set fld_cb [::model::mdlMatrix $colFrm.cb fldhandle "f" -rows 6 -columns 1]
pack $fld_cb
client ReleaseHandle
mod ReleaseHandle
fldhandle ReleaseHandle
On successful execution of the command, it will create the mdlMatrix widget.
