::mdlCollector
This command creates a mdlCollector widget that is tied to a Reference data member of an existing entity in the model.
::model::mdlCollector path entityHandle dm text args
MotionView Tcl GUI
- path
 - The full path to the newly created widget.
 - entityHandle
 - A handle pointing to the entity that contains the data member.
 - dm
 - The name of the data member that will hold the value.
 - text
 - The text that appears on the selection button.
 - args
 - A list of '-' separated flags to configure the mdlFileName widget's behavior.
::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity mrk Marker m_0 "\"Marker 0\"" "" ""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set coll [::model::mdlCollector .dlg.frm.coll mrk "origin" "Point" -reference ]
grid $coll -row 0 -column 0
mrk ReleaseHandleErrors
Returns the path to a mdlCollector widget if successful, otherwise an error code.
