hwISession ApplyReport
Applies a report.
hwISession_handle ApplyReport report_name, mode, autofit, report_colors, num_params, params
HyperWorks Tcl Query
- report_name
 - The name of the report (for example, "rep_def_1").
 - mode
- overlay
 - Overlay the report onto the current session.
 - append
 - Append the report to the current session.
 - replace
 - Replace the current report.
 - autofit
- true
 - Autofit plots.
 - false
 - Do not autofit plots.
 - report_colors
- true
 - Use report colors.
 - false
 - Do not use report colors.
 - num_params
 - The number of parameters.
 - params
 - Additional argument for each *Parameter() statement in the report (report_name).
sess1 LoadReport bumper.tpl
set autofit false
set report_colors true
sess1 ApplyReport "rep_def_1" append $autofit $report_colors 1 bumper.d3plotError
Success (0) or an error code.
