hwISession CaptureWindow
Creates an image file of a window on the current page.
hwISession_handle CaptureWindow win_id, type, filename, dimension_type, width, height, quality
HyperWorks Tcl Modify
- win_id
 - The ID of the window which needs to be captured.
 - type
 - The type of file. Options include: BMP, JPEG, TIFF, PNG, and Clipboard.
 - filename
 - The file name of the captured image.
 - dimension_type
 - Specifies the width and height units of the final image, which can be in percent or pixels.
 - width
 - The width of the captured image in percent/pixels.
 - height
 - The height of the captured image in percent/pixels.
 - quality (Optional)
 - The level of compression (default is 100). This is used only in JPEG type captures.
hwi GetSessionHandle sess
sess CaptureWindow 1 png Pic.png percent 150 150;
sess CaptureWindow 2 jpeg Pic.jpeg pixels 1280 960 90;
Error
Success (0) or an error code.
