hwISession SaveReportTemplate
Save the current session to a report template.
hwISession_handle SaveReportTemplate filename
HyperWorks Tcl Modify
- filename
 - The destination filename for the report template.
mySessionName SaveReportTemplate myfileError
Success (0) or an error code.
3 = HW_InvalidHandle - The handle used to invoke the method is no longer valid.
HW_MissingArg - Filename is an empty string.
