hwISession SaveSessionFile
Writes the session to the given filename.
hwISession_handle SaveSessionFile filename, savealldata
HyperWorks Tcl Modify
- filename
 - The session file to be written.
 - savealldata (Optional)
 - Allows you to save all the data in the session file as opposed to only references to the data.
mySessionName SaveReportTemplate myfileError
Success (0) or an error code.
