Runs a Tcl/Tk script in a protected manner according to
    the specified execution mode.
      hwISession_handle
        PerformBatchOperation script, exec_mode
      HyperWorks Tcl Modify
          - script
          - PerformBatchOperation runs the specified script in a way that
            ignores user mouse clicks or keyboard input while the script is running. This provides
            operational protection for the caller and is accomplished by running the script within a
            ‘UI lock’.
          - exec_mode (optional)
          - By specifying the exec_mode option, you can specify a variety of conditions, or
            ‘execution modes’, under which the specified script is run.
          - There are two primary execution modes: execution scope and render lock state.
          - Valid execution scope values are currentscope and
              globalscope. They are mutually exclusive.
                - currentscope
                - Runs the script at the current scope. Specifically, the script runs at one level
                  below the current Tcl callstack level.
                - globalscope
                - Runs the script at the global Tcl scope and is the
                  default. Specifically, the script runs at Tcl
                  callstack level 0.
          - The execution scope dimension is important if Tcl
            uplevel or upvar commands are used in the implementation of the script to be run.  In
            these cases, currentscope must be specified.
          - Valid render lock states are renderlocked and renderunlocked. They are mutually exclusive.
                - renderlock
                - Runs the script inside a render lock and is the default.
                - renderunlock
                - Runs the script only inside a UI lock.
          - The render lock state is primarily used to control flicker as a render lock ALWAYS
            forces a redraw of each visible page area at the end of script execution.
          - The values from the two dimensions can be specified in any order and with any
            delimiter (space or comma, for example).  If a mode is not specified, the default value
            will be assumed.
    Examples
      To run the
Tcl/Tk script myScript at the current
Tcl call stack scope within a Render
        Lock:
[::hw::GetSessionHandle] PerformBatchOperation myScript "currentscope renderlock" –
      To run myScript at the current scope and with no render
        lock:
[::hw::GetSessionHandle] PerformBatchOperation myScript "current scope, renderunlock"
      To run myScript at the global
Tcl scope under a Render Lock.
globalscope” and “
renderlock” are the default execution
        modes.
     Error
      HWInvalidArg - Specifying invalid modal combinations such as
          "currentscope
        globalscope" results in this error.
    Keywords
      Tcl
      Tk
      script
      commands
