hwISession CaptureAnimationByWindow
Creates a video file of a window on the current page.
hwISession_handle CaptureAnimationByWindow win_id, type, filename, left, top, right, bottom, dimension_type, width, height
HyperWorks Tcl Query
- win_id
 - The ID of the window which needs to be captured.
 - type
 - The type of file that you want the captured movie to be saved as. The available file types are: AVI, AMF, and GIF (one file contains the entire animation) or PNG, JPEG, BMP, and TIFF (a numbered series of still image files comprising the entire animation).
 - filename
 - The file name of the captured video.
 - left
 - The coordinate of the left side of the capture region, in screen percentage (a decimal between 0 and 1).
 - top
 - The coordinate of the top of the capture region, in screen percentage (a decimal between 0 and 1).
 - right
 - The coordinate of the right side of the capture region, in screen percentage (a decimal between 0 and 1).
 - bottom
 - The coordinate of the bottom of the capture region, in screen percentage (a decimal between 0 and 1).
 - dimension_type
 - Specifies the width and height units of the final animation, which can be in percent or pixels.
 - width
 - The width of the captured video in percent/pixels.
 - height
 - The height of the captured video in percent/pixels.
hwi GetSessionHandle sess
sess CaptureAnimationByWindow 0 gif Video.gif 0.1 0.1 0.9 0.9 percent 150 150;
sess CaptureAnimationByWindow 0 avi Video.avi 0.2 0.2 0.8 0.8 pixels 1280 960;
sess CaptureAnimationByWindow 1 png Video.png 0 0 1 1 pixels 800 600;
      Error
Success (0) or an error code.
